8-27-2012 |
1.50 |
D6 audio - 396 audio - co pilot ptt |
Tested the audio connection from the Garmin 396 to the audio panel. I tried last night to find some audio on the 396 but could not. I do not have an XM radio subscription. It occured to me that I could test the connection from the plug that goes into the 396 to the audio panel using my android phone and playing music. I plugged the 1/8 in plug into my phone as was treated to "Surfer Girl" by the beach boys. It works. Put a pin on the end of the green/blk wire that leads from the variable resister to the rear of the Dynon D6 and installed it into position 18 on the D6 connector. Labeled it "audio out". I finished off the ends of the two wires that were to go to the co-pilot PTT on the co pilot stick, labed them "co pilot ptt" and secured them so that they can later be used for that purpose if I decide to do so. At this moment, I do not intend to have a ptt on the rear stick. Labeled the marker beacon antenna cable inside the fuselage, aft of the spar. |
