7-28-2012 |
5.00 |
air switch - pitot static - audio panel |
I am writing htis on Sunday July 29, the day after the work was accomplished. I was too tired to complete the log last night. Actually, I don't remember clearly what I did excapt to work on the air switch, determining the place to locate it on the aft wall of the baggage compartment in a position so that the small adjustment screw can be accessed from the baggage compartment. Determined that the Dynon D6 attachement to the audio panel requires a 10k ohm varible resister in line. I went to skycraft and bought one. Drilled a hole for it in the drop down tray. Dick Isherwood says that he did not even bother with the resister. Perhaps I should not have had either, but I have it now. I will wire the GRT Sport pin 20 to the audio panel. It is for future use, but I might as well install it now. |
