4-16-2012 |
5.00 |
GRT removed for return, ICOM powered up etc |
I emailed GRT today and told them that the Sport EFIS failed to power up. They asked me to send it to them. Tonight I removed it from the panel and packed it to ship to them. I installed the ICOM A200 radio and powered it up. It is a bitch to install because it does not want to seat into the tray. Connected the COM1 and NAV1 radio antennas to the rear of the SL30 radio. Put the strain relief bar on the J1 connector of the audio panel. I could not do the same with the J2 connector because I cannot find half the bar. While working with the J2 connector a black wire used to jump the shields of two of the shielded wires can off. Identified the shielded cable that runs behind the radio stack and stops as the Garmin 396 plug connector. I will have to figure out what that goes to......audio? Designed and partially fabricated a GPS tray that will go in front of the firewall. I think I will leave the GPS antenna in a place where it can easily be removed in order to use it in the L2 as well. |
