Date:    11-6-2011
Number of Hours:    4.00
Brief Description:    transponder antenna - clock - avionics lighting
Connected and labeled a wire from the lighting bus for the instruments to output 1 on the LC40 dimmer module.
Worked on wiring the clock. Attached the tiny pins to the ends of 24awg wires, then soldered them and attempted to install them into the small connector. Two worked out ok. The last one would not engage in the connector for no apparant reason. While I was working on that issue, one of the others already installed broke off. I will have to order new pins and a new connector from the maker.
I did manage to install the antenna connector into the back of the garmin 327 transponder using the snap ring that I bought at skycraft. I then reinstalled the back onto the tray of the tranpsonder.
