10-31-2011 |
3.00 |
Wiring big red light and ampmeter sensor |
Connected the wiring from the big red light to the EIS connector, violet wire. Connected a white wire with red tips from the other side of the big red light to the main hot bus behind the panel with a fuse link supplied by grt inline at the bus. Connected the green wire from the ampmeter sensor (donut) to the grey/black wire for aux 5 on the EIS. Identified the following wires that need to be connected: EIS yellow/white -------serial in red/blue audio 2 out green/black serial out From the stick ? green green/black PTT white/Black White Coiled and tied the gray/red wire that goes to aux 6 on the EIS. It occured to me that having a hot buss that is open behind the panel may not be a good idea. I may have to rethink that. |
