10-10-2011 |
6.00 |
avionics ground block replaced, power and ground c |
Realized that the avionics ground bus would be too small to meet the need. I shopped at Skycraft and found a larger bus. I removed the old bus and replaced it with a new larger one. Reconnected the ground wires to the new bus. Made power and ground connections to the Dynon D6 and Audio Panel. I will have to extend thew power wires for the transponder and the GRT. |
