10-4-2011 |
4.00 |
mount clock in panel, design antenna wiring plan |
Used power point to create an antenna plan identifying the location of each antenna and major wing wiring runs. Used a template previously created to mark holes in panel for the clock/g meter. Drilled holes in the area where I used JB weld to fill previous holes that were incorrect. Temporarliy mounted the clock/g meter. |
