Date:    8-8-2011
Number of Hours:    4.00
Brief Description:    wiring ICOMM radio and GRT Sport
I completed wiring the ICOM A200 com radio, except that I realized that I had reversed a couple of wires. I removed one of those wires but have not been able to get the other one out.
I started wiring the GRT Sport EFIS. I pinned and installed the blue data wire from the Garmin 396 cable to pin 30 on the Sport.
I also installed a plastic loop on the ICOM to use in routing wires.
I was confused about using pin 37 on the sport to connect with the SL30. The instructions were contadictory. I emailed Carlos at GRT with that question.
