9-27-2010 |
3.00 |
Drilled and clecoed baffle seals |
Dick Isher wood helped. We cut the baffle material and installed it with clecos on the back and sides of the engine baffles. We put the cowling on and the fit seems good. One issue is that the top and bottom cowlings now have about a 1/8 gap between them at the firewall. Previously they fit pretty much perfect. Perhaps the pressure of the seals on the top cowling is causing this. |
