4-27-2010 |
2.00 |
pass thru for wires and scat hoses |
Created paths for spark plug wires on each side of the rear baffles. I am using plastic wire grommets that I mounted to the baffle with #8 screws. I made the holes for the grommets to mount in by using a step drill to open two 3/4 in holes next to each other. I cut two holes for scat tubing to cool the Emag and Pmag. The holes are 11/16 in and the black tubing fits well. I made a 1" hole for the fuel line which runs from the fuel servo to the spider. The hose will come up the back of the engine, through the baffle then to the divider. I made the hole too high for the hose to fit, it is about 1 to 2 in short. I may make another hole further down the baffle and use the first hole for a 1" scat tube to cool the mechanical fuel pump. |
