Date:    3-31-2010
Number of Hours:    3.50
Brief Description:    fitting- finger spacer-replace angle on corner
Dick Isherwood helped.
I used the paint stick method to elevate the top cowl 6 inches above the lower cowl. Tried to scribe a line along the baffles 6 inches down from the inside of the top cowling. I was not confident of the accuracy of that line.
Trimmed a little off the top of the starboard aft side baffle. There is a little still left to trim
Made the finger spacer for the back of part 7.
Replaced the ill fitting flange that I cut off the back port corner with a piece of angle. Drilled and riveted it in place. I still have to finish two of the rivets because I could not get to them with the piece in place.
