12-25-2007 |
1.00 |
nosewheel and tire |
Installed the new inner tube marked Shin from aircraft spruce into the tire, and mounted onto the nosewheel. I torqued the 3 bolts to 90 in pds. Filled both mains and the nose tire to 40 psi. I will check and see if it leaks. |
