Date:    3-19-2007
Number of Hours:    2.50
Brief Description:    starter relay
19 March 07- 2.5 hours
Worked on the installation of the starter relay. Installed the diode on the relay. Drilled holes for the relay. Discovered that the holes would have been better if drilled a little higher. The holes were also too close together. I used a dremel to open the slot on one side of the relay mount to make up for the closeness of the mounting bolts. It was slow going. I will have to continue about another 1/8 and/or trim the corner off the battery tray so that the tray does not interfere with the lugs on the relay.
Also drilled the holes in the control column for the stick mount out to ΒΌ inch. Located the bushings that go into the stick and hold the AN4 bolts. The bushings for both the front and rear sticks are a bit wider than the control column. It seems that I will have to trim them to fit.
