6-28-2011 |
2.00 |
FPS position indicators |
Checked the wiring for the positon indicators for the flaps and trim. All was correct except that a green wire had come loose from its connection with an extension that led to the fps relay board connection. I repaired that connection with a snap type connector that I acquired at skycraft and used on other awg 24 size wires. I removed the air switch since it was in a place that would be impossible to get to in order to adjust its sensitivity. I still cannot get my head around the required wiring for the accidential flap deployment prevention system. I email Rich and he just now returned the email, but I still don't understand it. |
