Date:    6-13-2011
Number of Hours:    0.50
Brief Description:    warning light switch
Worked on attaching a 22awg wire to the back of the warning light switch. First I tried an 18 awg wire but it was too think to get the strands through the slot in the tabs on the back of the switch.
The 22 awg will work. I got it set up to solder but could not find my soldering iron so I worked on the snout extension and finished that up. Then of course, I found that the soldering iron is in the mount on the stand where it is supposed to be.
