6-1-2011 |
5.00 |
wiring |
Worked on the wiring for the warning lights. Made good progress. I still need to wire the switch and run a power circuit to the aux fuse block and install a 5am fuse. I ran the canopy closed warning light ground wire that will attach to the switch, through the panel and aft. I will later attach that wire to the switch for the canopy closed function. Made and installed a wire from the aux main fuseblock to the main bus behind the panel. Found a crimper in my tool box that has the butt cheek function that I need to install the end fittings that go into the bluesea fuseblock. I used that crimper to install a fitting on the red EIS power wire and install it in the fuseblock. Developed a load analysis spreadsheet. Realized that I still need to run power from the master circuit to the avionics switch. |
