5-27-2011 |
3.00 |
EIS wiring and power distribution |
Installed the battery and tested circuits.I still need two wire the main bus to the power supply. I could not locate a suitable wire to run power to the main bus. Installed the hose and flowscan device between the mechanical fuel pump and the fuel injector servo. Firesleeved the flowscan and secured it with two hose clamps. Ran a wire from the flowscan to the ground tab on the firewall. Connected the wires from the flowscan device, via molex connector, to those running from the EIS. This completes the FWF wiring. |
