5-12-2011 |
3.00 |
Wiring..alt..e/p mags |
Wired: The emag and pmag p lead wires from the mags to the switch on panel. The emag and pmag 12v power wired from the mags to the circuit breaker. Alternator field wire from the Master/Alt switch to the alternator. Emag breaker to main bus Pmag breaker to main bus All connections were labeled The only remaining wiring for the mags is the tach wiring. I will need to afix the switch for that wiring. I will have to make a temporary panel. |
