5-5-2011 |
2.00 |
EIS wiring |
Purchased orange wire and blue wire today from skycraft, along with yellow heat shrink. Extended the orange wire from the EIS bundle along the wire route to the fuel pressure sender. Ran blue wire from FWF to the z frame where it will connect to the 4.8v point. I will install a resistor at that point. I will also connect the blue 4.8v wire to the orange wire. Extended the two wired for the floscan connections for power and signal from the end of the EIS wire bundle to the area where the wires will connect to the floscan. I labeled the ends. Heat was applied to the heat shrink over the connections for the EGT and CHT wires on the starboard side. I then put a piece of conduit over those wires. I could not find my solder gun to solder the resistor into the blue 4.8v wire. |
