5-2-2011 |
2.50 |
EIS wiring |
Installed adel clamps to make a path for the wiring across the engine from starboard to port. The main adel clamps are in place. Cable ties are used now where the smaller clamps will attach to the larger clamps. The reason is that I will wait until all the wires are run to determine the size of the smaller clamps. Tried to install the 4.8 v wire to a point on the firewall as a junction point, but had difficulty with the size of the spade fitting on the end. It is loose with the fittings I have now. Made up a wire to attach to the orange/black wire in the EIS harness, which is the oil pressure sensor wire. The harness wire will not react the sensor so I added a length of 18awg wire and attached it to the sender unit. |
