Date:    3-22-2011
Number of Hours:    3.00
Brief Description:    hose fittings, breather tube, alt cable
Took the Starter cable to Skycraft where I replaced one end fitting that I recently put on with another more appropriate fitting. Purchased a teflon size 6 wire for alternator output.
Dick Isherwood helped tighten the oil cooler fittings and reconnect the oil hoses. We determined how to mount the oil breather tube. I drilled a hole in the firwall to put a clamp to secure the breather tube to the firewall.
I fitted the fuel hose from the mechanical pump to the fuel injector body. It came today from Vans.
Dick tried to bend a short pigtail for the fuel line between the high pressure pump and the aft side of the firewall. The piece is so short that the line kinks when we try to bend it enough to make it fit.
