Date:    3-7-2011
Number of Hours:    2.00
Brief Description:    FAB alignment shop organization
Determined that the FAB, which is not aligned properly with the snout of the cowl, can be adjusted by turning it so that the front end is toward the snout. I will have to make a new top plate in order to do that. I put it in what seemed to be the correct position and put the lower cowl in place. The alignment was correct so I marked the top plate and spacer.
Also spent some time organizing bolts, washers etc in plastic boxes.
Determined what latch to use for the oil door, the KM610-4 available from B&B at 913-884-5930 for $10. It is the button like on a cessna.
Established a list of things to order.
