4-27-2010 |
1.00 |
fuel hose from servo to divider |
I worked on the placement of this hose. I made a hole in the back baffle to run the hose through and discovered that the hose is 1 to 2 in short if it runs through that hole. It may work if I make another hole further down the baffle, but then again it may still be too short. I have to decide whether to install the flowscan 201 transducer in this line, which will make its length moot, or not. I also cleaned up the shop. |
