3-4-2010 |
3.00 |
riveting mounting strips to airframe |
Dick Isherwood came by with the 3-6 rivets that I needed for the mounting strips for the camlocks. We riveted the mounting strips on both the top and bottom at the firewall. I noticed that the holes I drilled in the mounting strips to attach the skybolt fasteners were drilled out to 1/8 inch instead of the 3/32 that is proper. I think that the edge distance on the fastener will be sufficient if I drill out the hole in the fastener to 1/8. |
