Date:    10-13-2008
Number of Hours:    3.00
Brief Description:    remake of spacer for fuel servo
At vo tech I began to remake the spacer that goes between the fuel servo and the FAB. The previous spacer was about 1/4 too thin. I started with a piece of aluminum stock. On a milling machine I shaped it to the correct size although about 1 1/4 in thick which is too thick but will allow for adjustment of the size. I cut a hole in the center the size of the gasket.
