1-19-2008 |
5.00 |
control linkage, throttle cable hole |
Drilled a 1" hole for the throttle and mixture cables to pass through. I installed a bushing in the hole, but it was a little loose. That is probably because I held the drill with the hole cutter at an angle due to the cramped quarters. I put some clear rtv on the grommet to secure it. Installed the bellcrank for the elevator. It was a bit of a puzzle to get the washers alongside the bellcrank. I made a holder out of a plastic card, to hold the washer while I manuvered it into position. Installed the pushrod for the elevators. Attached the pushrod that goes forward to the control sticks. Worked on installing the aft control stick. I had to reduce the length of the bushing to get it to fit. I have not yet installed the bottom portion of the aft stick. |
