1-12-2008 |
5.00 |
Wire batt cables, check electrical system |
I made cables for the battery from #2 welding cable I bought at skycraft. I had the skycraft guys afix the end fittings. On a couple of the end fittings the holes were 1/4 in and I had to open them to 5/16 with a drill. On another end fitting, the hole is large enough to have the screw head that attaches it to pass through the hole. I am using a washer on that fitting. Stefan King came by and spend several hours with me checking out the electrical system. We discovered that I had made some mistakes which we corrected. The wiring to the fule pump relay was wrong. Some of the fittings in the back of the fuseblock were installed in wrong orientations, so that the fuse would not attach to them. We corrected a couple of those, there may be one or two more that will require correction. |
