1-4-2008 |
1.00 |
main gear brake flange attachment |
Installed the screw that holds the brake flange onto the axle of one of the main axles. I had to file down the washers just a bit to get the to fit. Made another set of washers for the opposite main axle by drilling out two washers with smaller holes to size 5/16. Located the bolts to attach the brake portion to the axle. |
