6-18-2009 |
1.00 |
More work on the new 3rd left skin. |
Today I finished prepping the new 3rd left skin by drilling out the pitot and spar attach holes. I then installed it on the skeleton and aligned it with the 2nd and 4th overlap holes. Once I had a cleco in each outer rib, I double-checked alignment and ratcheted it down onto the skeleton. I then put clecos in all of the predrilled holes and then drilled out the outboard line of overlap holes on the top of the wing. |
