3-30-2009 |
1.50 |
Aileron cable retainers and fairlead install. |
Today I made a small amount of progress on the other aileron cable retainers until I realized that I don't own a 10-32 tap (for the retainer screw). So I moved on to the aileron cable fairleads. I installed the root one on the left wing. I then measured the hole location and drilled them into the half ribs. Next I strung the aileron cable...ummm, I mean a clothesline from the root to the bell crank and marked the location of the other fairlead. I then drilled and clecoed the outboard fairlead into place. |
