8-14-2008 |
1.50 |
Finished redrilling the left flap nose skin. |
Today I finished drilling the left flap nose skin to the ribs that go against the hinges. It was quite a process. First, I marked over 1/2" on the spar and redrilled the attach angles to this location. Then I clecoed the nose ribs to the attach angles and installed the nose skin to the spar. Next, I marked the nose skin out 1/2" from the current holes that border the hinge locations. I first drilled #40 holes to make sure that I was lined up properly. Then I menuvered the ribs to line up with the holes and enlarged the holes to #30. WHEW!!! Finally I marked the location of the ribs on the skin so I can accurately trim the skin to the proper size. |
