2-2-2008 |
2.00 |
Drilled all the nose ribs to the aileron spars. |
Today I fitted and drilled the nose ribs to the aileron spars. I used a simulated skin to center the rib top to bottom. I realized that I should probably line up the balance tube holes so I don't have a problem inserting the tube later. I found out that one of the linkage tubes that I purchased for Avipro was the right size (3/4") and inserted it to line the ribs up. |
