Date:    8-21-2007
Number of Hours:    1.50
Brief Description:    Cut aileron and flap nose skins.
Today I continued to cut the remaining aluminum that needs to be bent on an 8' brake so that I can do it all in one trip.
It begins by measuring and marking a piece of aluminum, then it is rough cut using a phuematic shears. Then the piece is moved to the bench and clamped down using a piece of MDF. Next, the edge is routed to create a straight line and finally the edges are deburred.
