Date:    6-29-2007
Number of Hours:    1.50
Brief Description:    Continued to fit and drill rib attach angles.
Tonight I continued to fit and drill the rib attach angles to the left main spar. I finished by making the special angle that attaches at the splice plate. This involved making 2 more spacer pieces that go under the angle so it is flush with the splice plate. Then cutting the angle to allow the spar attach piece to go under it.
