Date:    6-25-2007
Number of Hours:    1.00
Brief Description:    Began drilling the rib attach angles.
Tonight I began drilling the main spar rib attach angles. First I had to get them bent to 90 degrees. When I first bent them, I had only bent them to about 80 degrees...unacceptable. Once they are at 90 degrees, I put them in the vice and drill 4 holes for the ribs to attach to.
