Date:    5-15-2007
Number of Hours:    1.50
Brief Description:    Finished riveting the caps on the left rear spar.
Tonight I riveted the left rear spar cap strips and splice plate. I only made 2 "smiley" faces on the spar web...both of them on the splice plate. My bucking bar hit the cap strip both times and bounced off the rivet making a small mark. Although not enough to worry about. I will leave the rib attach angles clecoed in place until assembly in case I want to remove them for drilling.
