Tonight I began the "scary" task of riveting the left rear spar. I was a little freaked out about driving the first few rivets...didn't want to ruin all the hard work I'd put into the spars. So I drove about 50 into a practice spar and felt comfortable. Then I began to rivet the spar. Piece of Cake!! Once I got into a rythm, it went pretty quick. I started by riveting 5 on the tip end. Then 5 on the root end. Then did 5 in the middle of that. Then 5 in the middle of each segement to split the spar up. This keeps the load even when riveting.
