Date:    2-27-2007
Number of Hours:    1.50
Brief Description:    Began match drilling the rear spar cap strips.
Tonight I began match drilling the rear spar cap strips. I have them all aligned and clamped together. Then I was trying to figure out how to keep the holes aligned after they have been drilled. I couldn't find any bolts or screws that were skinny enough and long enough. Then I thought, "Hey! I have 3/32" welding rod!" In the second picture, you can see the rod cut and bent on one end to stop it from going all the way through the hole. Works great.
