Well, the long layoff bit me again (you'd think I'd have learned by now...). I was all gung-ho to get the stiffeners drilled to the tank covers. So I lined them up to the left tank cover and drilled both stiffeners to the cover. I then realized that I drilled them to the outside of the cover!!! Not a big deal; I just went back and drilled them to the back using the holes in the cover and making sure they were offset from the old holes in the stiffeners. That's why you see two sets of holes in the pic and see it hanging over the edge of where the tank cover will intersect the wing skins. Now I just have to trim it a bit and re-deburr/countersink the holes in the stiffeners and I can move on to the right one.
