4-19-2007 |
2.30 |
Sanding and Filing |
The right top horizontal stabilizer was sanded to the point of being ready for finial finish. The rudder was extensively worked on with filing and sanding as necessary. I also rolled on a coat of Advantage primer on much of the fuselage bottom and the 2/3 of the flap bottom. I use 3 coats at least when this is done. |
