Date:    11-19-2006
Number of Hours:    5.00
Brief Description:    Left Tank Work
I transferred the wcp to the outer end of the tank. The tank was then test hung on the aircraft. I adjusted it as necessary and then attached it with 2 screws temporarily. My 14 year daughter held the tank while we set this up. Next I marked the locations for the 3 tank brackets. These were made previuosly from CAD files I did and sent to a service company via the internet. Production quality parts are always the result this way. The tank was then removed. I then disassembled the entire back of the tank. The holes for the bolts for the brackets were drilled and the brackets were bolted and "glued" in place with firbrglass resin. I also added the tank drain mount that was another CAD designed piece I had made some time ago. The small rear bracket that goes on the fuselage was also installed today.
