I designed and installed an adjustable door stop for the inner door. THis allows the door to completely closed, but stop hard in place. I have started the other one for the pilots side as an addition. I also changed the rounting on the hydraullic lines on the right seat side of the aircraft to clear the gear door more comepletely. The plate for the front of the hinge pin was begun. Since it is stainless steel to mate with the rod I will take it to a friend to weld. I, so far, do not weld stainless.
