Date:    4-22-2007
Number of Hours:    2.50
Brief Description:    Smoothing the Bottom of the Fuselage
I power sanded a large portion of the lower fuselage and flap area. It then spot glazed several areas. More sanding after of course! The rudder was also worked on in the same manner. I finnished out this session with a primer coat on most of the rudder. This was the usual 3 coats rolled on of Advantage primer.
