Date:    3-30-2007
Number of Hours:    1.00
Brief Description:    Priming
The wings were primed agaib on both the top and the bottom with urethane primer. It appears 3 coats is a good amoun to use per primer application. This amount will dry over night yet has a high build to sand off as necessary.
