3-24-2007 |
5.00 |
Sanding and Filling |
The same routine continues. Until the surface is completely smooth I will not be happy. However, this is not to say that huge amounts of filler end up on the aircraft. Rather, many very thin layers end up being applied with much of the material actually sanded off. The goal is only to fill the low areas, not add a skin of filler to the whole aircarft. |
