Date:    2-17-2007
Number of Hours:    2.50
Brief Description:    Wing Changes
I glued balsa to the rear of the flaps to correct the outer edge error the original builder made. These will be sanded to shape and fiberglassed for strength. I also filled and sanded the aileron. The control arm was remounted to it and the temporaru access holes for the bolts were filled with foam and glassed over.
