Date:    1-9-2007
Number of Hours:    0.40
Brief Description:    Bleeding Brakes
Note: I have all the brake information in this section since the system is mounted on the rudder pedals.I found a manual for another brand of brakes on the internet that had a good suggestion in it. It suggested "filling" the brakes from the bottom up instead of bleeding them. This works very well for this istallation. Use a hand oil can and 1/8" clear plastic tube to pump the fluid into the bleeder valve and thence up through the system. Easy and very effective! I did one half of the system today.
