Date:    12-28-2006
Number of Hours:    5.00
Brief Description:    Change Forward Pedal Assembly
We jigged and welded the forward pedal assembly so it would not twist. The new system of joining the pedals uses 4130 steel 1/4" thick since it will not bend. I used AN4 bolts to fasten the joints where they are removeable. The pilots end was streched over .25" and drilled out a similar amount. We then cut off .25" resulting in shifting the pilots pedal .25" to the left. This is being done to clear the wheel well with regards to the right pilots pedal.
