Date:    10-28-2005
Number of Hours:    8.00
Brief Description:    Fuel Tank Screw & Inspection Plate Nutplates
Finished riveting left wing fuel tank screw nutplates. Drilled and countersunk both spars for inspection plate nutplates. Riveted inspection plate nutplates to both spars. Countersunk all screw holes on both spars and primed holes. Trimmed tiedown ring brackets to correct length, drilled and tapped tiedown bracket holes. Drilled and mounted tiedown brackets to both spars, including aileron bellcrank brackets.Started rear spar work by deburring rear spars and doubler plates.
