Date:    9-13-2006
Number of Hours:    10.00
Brief Description:    Mounted Vertical Stabilizer
Fabricated elevator up stop and attached to fuselage upper deck. Trimmed VS front spar and mounted to fuselage. Drilled and bolted VS to front attach plate, elevator up stop, and rear bulkhead. Drilled and mounted rear tiedown to rear VS spar and rear bulkhead. Fabricated, drilled, and mounted rudder stops.
